Converting a parabolic curved surface to sheet metal - possible?
Tulkas33
Tulkas33
Attempting to make flatten-able surfaces with the sheet metal workflow so that I can create flat sewing patterns.
Converting this surface to sheet metal and flattening was no issue when I based the surface's curve on an arc. I now realize the curve needs to be parabolic, but an error says "can't calculate body thickness" when I select the tab.
Am I missing something simple or is it just not possible to convert if it's a parabolic curve rather than an arc?
Warmingup1953
Sometimes extend using Perpendicular works(better). You need then to add a fillet (small) before thickening away from the fillet. I keep my thickens to paper thin or less when simply making patternsCapture.PNG
Tulkas33
Is the fillet a required step? Seems like it would change the dimensions of the flat pattern slightly?
Tulkas33
Thank you for your solution. Hoping someone might have an explanation for why this works but the tangent flange does not. A tangent flange would give me a totally accurate pattern if doable. The pattern you showed me is slightly asymmetrical. I'm wondering if the flange is allowing it to distort as it flattens?
Warmingup1953
I didn't dig down into your Timeline, I simply jumped in in "Salvage Mode"! If you were to amend your sketch so as to include a 1mm line tangent to the curve rather than using extension that will probably yield results (Speculation only until I have a look again)
