Convert surface to solid patch not working for me :(
trialsin808
Observer Observer
trialsin808
Observer
Observer
Hi all I have a relatively clean prismatic convert from an STL but there are a few unsealed areas that prevent me from making edits like it were a solid. I have tried for 3 days straight and have no idea what steps I should take to get that orange icon to change to closed/solid.
Please can I have some pointers from the expert community?
EDIT: Remesh using less complex polygons. Then upon parametric export, select the face to patch, then stitch. The surface is closed.
now to make solid...
TheCADWhisperer
@trialsin808
Drewpan
When you converted the STL to a mesh did you also use the Repair Mesh tool? This
tool will usually fix 90% of "leaks" in a mesh. You may also need to use the Patch
tool for larger "holes". Try these and if you are still having problems then attach the
file and screen shots and the forum can have a look at it to try to solve the problem.
Cheers
Andrew
