Hi everyone,
Hope all is going well.
I recently started using fusion, (coming primarily from blender) to be able to do some parametric designs.
I'm working on bottle design the shape is visible on the sketch of screenshot "SC2.jpg", I'm trying to generate some asymmetric cuts that start small on the sides and get bigger as they run through the front of the bottle. (Purple lines on the second screenshot).
I'm working with a solid, made by lofting a couple of sketches at different heights with rail guides.
Then made a sketch that was then projected onto the surface of the bottle (purple line) to make the the cut.
Methods I tried so far:
(Method 1 - Sweep tool) type Path + Guide Rail, the guide rail is elliptical (on the same plane) further away as it crosses the front of the bottle -> error message "The path is not smooth"
(Method 2 - Loft tool) a couple of profiles along the path with incremental size, -> error message "Rail is not smooth, try to make the rail tangent continuous"
Both fail even though the bottle sketch is well constrained, using tangents in every corner.
Was thinking of going the surface route and try again, but have dedicated 10h+ already, wondering if anyone has an insight on how this could be achieved, or if it's even possible using fusion.
Thank you very much for your help.
