Construction Lines, working on mid plane
peter
peter
Saw another post about construction geometry. reply was that it's doable in Fusion 360. Any more info on how to do this?
Also, created a solid block, created a midplane, want to work on this midplane and create geometry. can draw on this ok but can't referenece edges of the t get location. Can do it on the face of a solid.
Any help?
Peter
Oceanconcepts
I don't know for sure if this is how Fusion works, but I've regarded construction planes (working planes) as infinite in extent- a one dimensional reference. What you see is just a visual reference.  To measure from something you would need to create a sketch that defined the edges you want.  If you want that to be the intersection of an object and the plane, then the Project or Project Cut Edges tools will place those lines on the sketch.
Ron
- Ron
Mostly Mac- currently M1 MacBook Pro
peter
Thank you!
