Constraints
Constraints
infoYYJRS
Constraints
infoYYJRS
How would you constrain the two objects so the  green line becomes midpoint of the two indicated end points?
TheCADWhisperer
infoYYJRS
Okay, here it is 🙂
What i trying to do is aligning  all four squares center, so i can form a patteren from the center to the left and right with the same distance. A sort of knurling 🙂
JamieGilchrist
Hi @infoYYJRS ,
To do this use a line between your two points and apply a horizontal/vertical constraint to the mid-point of the line and the end points of your green line.
Here’s with everything toggled on.  One thing to notice, I only used two dimensions in this scheme (the third one is a reference, that's why the "fx" in front of the dimension) and used constraints to get to the desired results.  I also did this in a second sketch and projected just the geometry  needed to try and keep the sketch as simple as possible
I've attached a version I created so you can take a look.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
