constraints
constraints
constraints
the message saying "it is over constrained"  so you can't use sketch dimensions the only solution I see is not satisfactory are you going to have a method to see the constrants and delete the ones you don't want and when.
jeff_strater
We are working on some things that will help:
1. changing the display to show the constraint status of sketch geometry.  So, fully constrained geometry will show in a different color
2. improving the solve in general.  There are cases where we report overconstrained that are not really overconstrained.  This is an extremely high priority
longer term, we want to also have more debugging tools, so that if you do get into a valid overconstrained case, we can point out which constraints are involved and let you decide which of those to remove
I hope this helps to answer your question
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
inchul.lee
Autodesk Support
Autodesk Support
* Edited the original post
Hi stewartryrie,
You may also suggest your idea in Fusion 360 IdeaStation.
There's an existing idea regarding sketch constraints, which may be similar to your expectation.
UI: Constraint visibility control
Inchul Lee
