03:52 PM
I have a fundamental question concerning constraints. Should all possible constraints be identified while still creating a sketch? If you create a component, sketch, body and the constrain that sketch how do you constrain the the first component to any subsequent component that you may create?. As an example i have created a cabinet with a left panel sketch and extruded it . I then create a second assembly (top) and extrude it. Both assemblies are independent and will stay together. I assume a collinear constraint would be required here.
Should i have created just sketches first, constrained them, then extruded them?
Thanks for your help
