Announcements
Constraint to a patterned sketch entity
New Fusion 360 user here (10ish years of Solidworks experience).  I'm trying to wrap my head around a sketch issue I've run across.  The attached image is a simplification to demonstrate.
To reproduce:
(1) Draw a line on a new sketch
(2) Pattern the line - in this case I made 3 along the horizontal axis
(3) Add a new sketch entity that has a some constraint together with one of the patterned lines
(4) Edit the pattern spacing
The sketch entity added in step 3 does not follow the edited pattern even though the constraint is still present.  If I attempt to add a new constraint, I get a 'sketch geometry is over constrained' error.
jeff_strater
That is most certainly a bug.  Good find, thanks for reporting it.  I will send this to our dev team to analyzed and fix
Jeff
[edit] filed as FUS-37969
Jeff Strater
Engineering Director
Type a product name
