Constraint selection
untrustedone
untrustedone
The selection of constraints that are on the permanent ribbon are not my most frequently used. I use symmetry, tangent, and concentric. Maybe the rest of the world does and that is your data, but it would be cool to select which constraints to put there.
Side note: why are not edit parameters not on ribbon?
HughesTooling
You can add whatever constraint you need to the ribbon like you can add any of the menu items to the top toolbar. For parameters you have a couple of options for now, add a hotkey like Shift+P or add it to the search Shortcuts dialog. In a sketch press S then start typing Parameters, click the up arrow to add it to the toolbox then just press S in the future.
Mark
Mark Hughes
Owner, Hughes Tooling
untrustedone
I wish I could subtract items.....
HughesTooling
What do you want to remove and from where?
Mark
Mark Hughes
