Constrain feature limitations for assemblies - Fusion
aleksei_ovsienko
Message 1 of 8
aleksei_ovsienko
Let's say I'm constraining a subassembly of three components (lets call them A, B and C) using Constrain feature. I normally need three references to constrain it in 3 directions.
So I select a reference on the subassembly - a surface on component A of that subassembly and select a reference surface on the mating component. Works fine.
Then I create a second pair of references within the same Constrain feature dialog to constrain it further. And I find that I can now only select references on the component A. All other components - B and C - of that subassembly can not be selected for references.
This is a problem. It should not work like that. I must be able to select any object on any component of the subassembly to constrain that subassembly. Because I'm constraining the subassembly, not its individual components that are already constrained within the subassembly.
Can this be fixed please?
Currently the workaround is using multiple constrain features to constrain a single subassembly.
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
Replies (7)
Message 2 of 8
heather_tracy
Hi @aleksei_ovsienko,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Heather | Community Manager
Message 3 of 8
aleksei_ovsienko
Thank you @heather_tracy . I know how to work around that, I don't need asstistance. I'm just drawing attention to the problem with how Constraints work so it can get fixed.
Message 4 of 8
TrippyLighting
I would not hold my breath. We've argued for many, many years for the need for constraints (mates in SolidWorks and other CAD systems), before they were implemented.
Message 5 of 8
TheCADWhisperer
@aleksei_ovsienko
Can you Attach the workaround so that I understand the issue?
Message 6 of 8
aleksei_ovsienko
Yeah. Here's the link. I created a simple assembly of some random plate and a subassembly.  You can see that I use three separate Constraint features to constrain the subassembly relative to the grounded part and each of these constrains references a different subassembly part because it is not possible to reference multiple subassembly parts within one constrain set.
 https://a360.co/4oMOwz1
Message 7 of 8
TrippyLighting
That can be achieved with a single rigid joint.
Constraints were not introduced to replace joints!
Message 8 of 8
aleksei_ovsienko
In this particular case - yes, it can be done with joints. I just created an example to demonstrate the issue. But in principle Constraints still need to allow the user to select references from all subassembly parts. It's just common sense.
