Constrain distance to outer rectangle
andrew_liyanage
Observer Observer
Message 1 of 8
andrew_liyanage
Observer
Observer
Hi all,
this is my second day using Fusion 360 and the first time ever using a CAD Software and I am still trying to figure out how this all works 🙂 I have a rectangle within a rectangle and I would like to define the distance on one side of the rectangle to the parallel side of the outer rectangle. I tried to use the horizontal/vertical constraint but it won't let me. How can I do this? I attached a screenshot, the yellow part is the distance I would like to define...
Your help is much appreciated!
Replies (7)
Message 2 of 8
HughesTooling
Just add a dimension?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
HughesTooling
If you want the rectangles centred you could add a vertical constraint between midpoints.
Select the vertical constraint, hold the shift key down, hover the pointer near the middle of a line until the midpoint is found and pick. Repeat for the other rectangle. Also please don't attach pictures, just paste them into your message from the clipboard.
Mark Hughes
Message 4 of 8
g-andresen
vert/hor constraint via symmetry
günther
Message 5 of 8
davebYYPCU
Using the vertical / midpoint and final dimensions.
Might help.....
Message 6 of 8
andrew_liyanage
Observer
Observer
Thank you so much, that's exactly what I was looking for, sorry this might have been a very straight forward task but as I am new to fusion I'm still finding my way around 🙂
Message 7 of 8
andrew_liyanage
Observer
Observer
Thanks for the advice and help
Message 8 of 8
g-andresen
I would also like to point out that, as @HughesTooling wrote, pressing and holding the shift key is important in the first method.
günther
