For me, “between faces” means “in the middle,” so an offset doesn't make sense.
günther
Hello
Thank you for your support
@g-andresen wrote:Hi,
Until now, I have connected the center of the blank to the center of the jaw with a joint and was able to enter an offset if necessary, which is why it makes sense to me even with a center constrain.
Christoph
Currently, I also find “traditional” joints more flexible and easier to use, which in some situations is facilitated by the use of joint origins.
However, I am curious to see what role component constraints will play after sufficient review.
Günther
