Connecting swipe/pipe in between Z plane and X plane
6578807431
Observer Observer
6578807431
Observer
Observer
Hi, I would like a connecting pipes from X plane to Z plane.
1. I tried to make the pipes using sweep from X plane 1st and then followed by from Z plane. However, they did not well connected, I want to make it smooth like a 1/4 circular shape on its edge.
2. With the same thing, I have another issue related to different height of the body (like the 2nd body extruded). When I make the pipes using swipe to connect the pipes, it only make the pipe when I use "cut", or it only make the extruded pipe without hole when I use "join". I would like them to have the hole either inside the 2nd body or outside the body.
Could someone help how to solve this problem? Much appreciated
Warmingup1953
TheCADWhisperer
@6578807431
Do you have a picture of something similar from the real world.
I suspect that you do not need all of those workplanes and your first sketch is not fully defined (missing logical dimensions).  If I start to add the missing dimensions - none of them make logical sense?
What is your true Design Intent?  I am sure there is an efficient, robust and completely predictable solution.
wersy
Or just like this?
