Connecting multiple bodies with a body that seamlessly extrudes through them?
Hi I am trying to extrude a small rectangular body through multiple sized bodies as a joint that connects all of them together. The bodies that the extruding body is going through start from bigger to smaller in size. Ideally I need the body that i am extruding to seamlessly size to each body that it intersecting through.... I thought the intersect operation would work but it doing the exact opposite, unless there is a way to inverse it?
Are there any other options that are a simple solution for this problem, rather than doing a loft between each individual body manually...?
innovatenate
Autodesk Support
Autodesk Support
Have you tried using the Intersect option? I think that is what you're after. You could use this in Extrude or the Model > Modify > Combine command.
Have a look at the screencast above for reference. I hope this helps.
Nathan Chandler
Principal Specialist
SaeedHamza
Here is an easy way to do it using the split body tool
Regards
Saeed
Saeed Hamza
This perfectly worked! Thank you
