confused... fusion does not stop for tool change
Message 1 of 26
Just keeps hogging away with my adaptive clearing bit when it should change to a horizontal clearing and a smaller bit.
Replies (25)
Message 2 of 26
HughesTooling
If the tools have different numbers it should stop. Are you using a standard post or something you modified? Going to need more info, if possible can you share the design? Use Export and save as an f3d and attach.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 26
https://a360.co/2IyCVk3.  I just imported the mesh. then moved to cam and set an adaptive with 1/4 bit. then a harizontal with 1/8 ball. clicked make g code.  then imported g code into easel.
Message 4 of 26
HughesTooling
Can you export the design and attach. The download links are a time waster. also which post processor did you use?
Thanks Mark
Mark Hughes
Message 5 of 26
maybe figured it out   everyone of my tools has a #1 in front of it  I guess I need to edit them
Message 6 of 26
HughesTooling
Yes, they need to match the tool library in your control.
Mark
Mark Hughes
Message 7 of 26
file attached
Message 8 of 26
renumber tools  still   no go.
Message 9 of 26
tool change says  no... now im really confused  LOL
Message 10 of 26
HughesTooling
Both tools are still #1 in your file you attached. Where did you renumber them, you need to renumber in the document library not your main libraries.
Mark Hughes
Message 11 of 26
g code tool change ?
Message 12 of 26
sorry for being  stupid .   where do I find document library ?
Message 13 of 26
FOUND IT.
Message 14 of 26
renumbered tools in document file. regenerated g code.....same result.
Message 15 of 26
HughesTooling
What do the too numbers show in the browser like I the image I attached above
Mark
Mark Hughes
Message 16 of 26
HughesTooling
Export your file and attach again. Still don't think you said which post processor you're using.
Mark Hughes
Message 17 of 26
etfrench
Something is odd in the gcode:
    (1001)
    (T2  D=0.1252 CR=0.0626 - ZMIN=-0.324 - BALL END MILL)
    (T3  D=0.25 CR=0. - ZMIN=-0.2753 - FLAT END MILL)
    N10 G90 G94 G17 G91.1
    N15 G20
    N20 G53 G0 Z0.
    (ADAPTIVE3)
    N25 M9
    N30 T3 M6
    N35 T2
    N40 S16000 M3
    N45 G54
    N50 G0 X1.7231 Y2.164
There is no other toolchange after N35.  I'm using LinuxCNC post.  Tool Ids were changed.  Setup1 was the input folder for post.
ETFrench
Message 18 of 26
HughesTooling
Think the T2 on line 35 is a preselect for a tool changer. So T3M6 will load the tool from a tool changer and line 35 preselects the next tool ready for the next operation. Need to know what post processor he's using and does his control have a tool changer and support preselection.
Mark
Mark Hughes
Message 19 of 26
Post processer: easel \ f360-easel
Just on an x carve no tool changer
Message 20 of 26
HughesTooling
Don't think that's one of the generic posts, can you attach it to this thread? Also the latest version on your file just so I'm looking at the same file as you.
Thanks Mark
Mark Hughes
