Conflic path in layers when using multiple objects
alain_rogerNVLMR
alain_rogerNVLMR
I'm new to Fusion 360 and I already created 2 models with Fusion, however when I export them to 3mf (to 3d print them), i get a warning message in my bambulab studio app as there is conflict between objects and respectively in their path.
I discovered the a single object 3d model has no issue, but once there are more objects in 3d models there is always such issue.
How can I do to avoid such issue in fusion ? For such a 3d model can not be a single object but an assembling of multiple objects. So how can I solve such problem ?
thx
jhackney1972
It could be that your model consist of more than one body and your slicer does not like it.  Use can use the Combine command to join them into one.  They of course much touch each other to do this.
Attach your model so the Forum users can take a look.  Open the model in Fusion, select the File menu, then Export and save to your hard drive.  Attach to a reply post.
John Hackney, Retired
