Compute Failed for joints
6 REPLIES 6
NuofanQiu
390 Views, 6 Replies
Hi, Fusion 360 community:
I got a problem with my assembly:
Warning: Revolute 23
Compute Failed
Warning: Revolute 41
Compute Failed
Warning: Revolute 12
Compute Failed
Warning: Revolute 34
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Warning: Rigid 1
Compute Failed
Warning: Revolute 2
Compute Failed
Warning: Revolute 3
Compute Failed
Warning: Rigid 4
Compute Failed
Warning: Revolute 5
Compute Failed
Warning: Revolute 6
Compute Failed
Warning: Rigid 7
Compute Failed
Warning: Revolute 8
Compute Failed
Warning: Revolute 9
Compute Failed
Warning: Rigid 10
Compute Failed
Warning: Revolute 11
Compute Failed
Compute Failed
Here is my assembly file, the problem comes out when activate capture history feature.
Is this problem related to closed-loop mechanism or nested components? Or it is just the problem with my assemble workflow?
I don't know why this warning comes out.
More description about this problem at here .
Thank you!
Labels (1)
6 REPLIES 6
TrippyLighting
in reply to: NuofanQiu
Did you also get the errors when applying the joints after you have enabled the timeline ?
I know that this will be a good bit of work. You can obviously limit this to just one leg. If that works (or not) we have a better indication of what to look for.
NuofanQiu
in reply to: TrippyLighting
Thanks for your reply.
Yes, I get errors about these joints when I enabled the timeline.
TrippyLighting
You did not answer the question!
  1. Delete all the joints
  2. Enable the timeline
  3. Re-create the joints.
Does that result in the same problems?
NuofanQiu
Sorry, I misunderstand your meanings.
I will try it.
jhackney1972
Attached is your assembly with the Capture Design History enabled.  I do not see any Joint issues.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
NuofanQiu
in reply to: jhackney1972
That is confusing. But any way, thank you for your work!
