Compound Angles
Compound Angles
Compound Angles
I was hoping that I could figure this out on my own, but no luck.  I searched but didn't really find anything that looked like it would work.
I'm trying to create a set of folding workbench legs.  It's a simple X design, so that when ratchet strapped against itself there is a pinch point at the top that would hold a crossmember to go across to an identical set. Each leg would be cut 15degrees front to back and side to side, therefore a compound angle at the top and bottom of each leg.
I've been able to design it with one bevel, but when I try to add in the other bevel it just doesn't come out right.
Any suggestions anyone?
TheCADWhisperer
Attach your attempt here.
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply.
laughingcreek
maybe this gives you some ideas
jhackney1972
I would create a common leg component using angled construction planes.  Then you can Copy and Paste/Paste New, depending if you want it independent, in your assembly.  Screencast shows you how I did it.  The Model is attached.
John Hackney, Retired
