components relationships
darek.lin
darek.lin
Forgive the novice simple question (;
On the basis of an existing component, I created two more components through the copy / paste operations of the component. New components have been created but there are some relations between them. When I change something in one of the components, the changes take place in all three components. Can I disable these relationships between components. I would like these three components to become independent entities.
lichtzeichenanlage
From novice to novice 😉
If you "Copy/Paste" a component they are linked in any possible aspect what's inside the component container. If you "Copy/Paste New" you copy the content of the container and each possible attribute is adjustable or extendable. This even includes modle parameters.
You can see the difference in this little screen cast an you can play around with the attached design, too.
darek.lin
Thank you very much. That's exactly what I meant.
