Components and Timeline?
LibertyMachine
Mentor Mentor
LibertyMachine
Fairly comfortable with the CAM side of things, but my modeling side of things is.....lacking, so forgive me if this might be an easy question.
Make a body. Tweak it so how I want it to look. Timeline shows me what I've done.
Make it a component and activate it, timeline goes away and only leaves the marker for "Component" Drill down through the tree and fine no timeline.
Mirror the body and make it another component, this becomes a "child" of the first component. Incorrect actions?
What did I do wrong? No, I did not click "Don't capture design history"
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
HughesTooling
The quick answer is you should create the component first with it activated design your part. What you could try if you've forgotten Rule #1 is don't use Create components from bodies, just create an empty component then select the first sketch and drag it in the empty component, if you're lucky all the other sketches and features will end up in the component as well, sometime you need to drag the other sketches though.
If you can undo what was in the screencast give it a try.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
The reason the timeline's empty when you activate the new component is because all the features and sketches are still in the main component, create components from bodies doesn't move the features with the body.
Mark
Mark Hughes
LibertyMachine
Gotcha, that makes sense.
I've seen mentions of R.U.L.E #1, but didn't actually know what it was. I spend most of my time over on the CAM side Smiley Tongue
Seth Madore
