Component jumps when editing joint
tomae
tomae
Any idea why this happens sometimes?  When I edit the joint the component jumps to the intended position.  But when I Ok the joint the component goes to some unwanted position. No amount of editing the joint can correct it.  I can unselect and re-select the components, I can move them around, whatever, but whenever I go to close it the component snaps to the same undesirable place.  The only way to fix it is to delete the joint and then re-add it.
-Tom
daniel_lyall
At the start of your vid there is a capture position wanting to be set, It's more than likely jumping back to it's last captured postion
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
tomae
Hmm, didn't notice that, next time I will look up there and see if that's the problem.
-Tom
