Appreciate the video.
One thing I should have said is this is a one off to get files to cut the flat 5mm plates on CNC plasma, I don't have a 4 axis so some bits will need to be cut and then angled via grinder.
Secondly, the wheels and U channel are bought, those are not actually being made by me, hence I didn't care about no tolerance built in. Worst case I will put oversize nylon wheels in lathe and clearance accordingly I figured. I don't have them yet to get actual sizes, I done this to get an idea for what I will need and what I could find available to order in UK. Now I know roughly what I need I would probably get something like-https://www.aluminiumwarehouse.co.uk/products/2-in-x-1-in-x-1-8-in-x-1-8-in-aluminium-channel?variant=423410...
Wheels- these will need modified slightly in lathe but quick job to allow for bolt, or I might find something else better suited with deeper look-https://www.castors-online.co.uk/product/icc-50mm-black-nylon-wheel-only-with-8mm-bore-4567?gad_source=1&gad...
I only really need the model to get a scale idea in cad and what brackets might look like to attach to my boat, plus the flat plates for cnc and round bars needed to cut/tig weld.
I didn't even know fusion could do some of the things in your video, appreciate the feedback and will start again. Stay tuned for MK2!!
