Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Complicated curve in two planes plus taper
3 REPLIES 3
374 Views, 3 Replies
I need to produce a pair of cart shafts which curve in two planes, start off square for about half the length and finish round and taper at the end.. I attach a similar drawing but it does not show the taper.. The top drawing is the top profile, the lower one the side profile. I am not concerned with the dimensions. The start of the shafts is on the left.Shafts.jpg
3 REPLIES 3
laughingcreek
maybe the attached will give you some ideas.  sketch 4 is produced using "project-intersecting curves", with the first 2 sketches as the input.
it's usually better from a curvature quality  standpoint to use surfaces to produce these types of curves, but that's a more difficult workflow to demonstrate, and I think intersecting curves work fine in this particular instance.
@laughingcreek wrote:
...I think intersecting curves work fine in this particular instance.
I agree with that!
.. but that's a more difficult workflow to demonstrate...
I don't necessarily agree with that. We've just grown comfortable with a workflow that doesn't make any sense e to normal people AKA non-Fuiosn 360 users 🙂
In order to get an intersection curve, which usually curves through 3D space you first have to pick a plane to start the sketch on. Intuitively that does not make any sense, because the intersected result isn't going to coincide with any plane.
in reply to: laughingcreek
Thank you for the reply. I am a newbie to Fusion 360 and CAD but after a bit of thought and a text book I have managed to produce a shaft. It needs fine tuning but I will get there.
Technology Administrators
