Complex web
Complex web
gatzkerob
Message 1 of 9
Complex web
gatzkerob
I'm having difficulty creating a "web" between the edges shown. It doesn't necessarily have to be a web, I just want to join #1 to #2.
#1 is curved on the xy plane
#1 is flat at the top
#2 is curved on the xz plane at the top
#2 is lower than #1
#2 is angled on the yz plane
I'd like to fill the blue space so the the top of #1 meets and "twirls" slightly to join to #2
I've tried web, rib, loft, sweep, and extrude. None of which create clean geometry at #1 and #2
Cheers.
Replies (8)
Message 2 of 9
TheCADWhisperer
File >Export and then Attach your *.f3d file here.
Message 3 of 9
gatzkerob
File attached.
The split faces on the bottom of the shelf may not be necessary. Maybe you know a better way of doing it.
Cheers
Message 4 of 9
TheCADWhisperer
I would start over from the beginning using what was learned from this attempt.  (perhaps not what you want to hear)
I would use symmetry about the origin.
I would fully define every sketch.
Use about 10 features to get this far.
Good luck!
Message 5 of 9
gatzkerob
Lol, definitely not what I want to hear but I'll take it constructively and try again.
Regarding the previous question though, how would I create a rib between two curves on different planes?
Message 6 of 9
TheCADWhisperer
I am reluctant to "put lipstick on a pig".
If you can create a very simple example that exhibits the same behavior as your more complex design - I might be motivated to take a second look.  Bottom line - I suspect the solution will be easy.
Message 7 of 9
gatzkerob
Ok, I took your 10-step challenge and simplified the previous model down to about 20 steps. Thanks for that - it was a good lesson on being resourceful with sketches.
I've uploaded a simplified mock-up of the full version for you to take a look at if you don't mind:
  • I'm trying to make a web between bodies #1 and #2 at the given points (approx).
  • The web should be perpendicular to #1
  • The web should follow any curvature, horizontally or vertically
  • The web should go flush from the top of #1 and #2 to the base
  • #1 should remain hollow
Cheers!
Message 8 of 9
gatzkerob
Here's an example of what I want:
The web in the image is exaggerated - it should only be 1-2 mm thick.
But you can see how it's flush with the top of #1 and #2 and follows their curves.
It took a lot of steps to create this, it would be insane to repeat the steps for 20+ more.
Mirroring / pattern is not an option as there are more of them in different places with different sizes and angles.
Looks like this is turning into a feature request!
Message 9 of 9
TrippyLighting
Whether insane or not, this did not take that many steps. If I had not cleaned up the design by removing the 2 helper surfaces and the all the split-off bodies, the added timeline section would only be half as long.
