Complex sheet metal flange shapes workflow
sonnie_b
Message 1 of 13
sonnie_b
Proficient in Inventor but learning Fusion.  I would like to create a complex shaped flange that uses an existing projected sheet metal geometry profile to produce the flange's shape.  Is there a way to sketch on a flange and add material to that flange? Or, sketch the shape of the flange you desire and extrude the thickness while selecting the edge of the existing sheet metal part you want to combine with?  In the attached pic, the edge with the red arrow is the bend edge and the sketch is the "flange" shape i desire.  Maybe i just need some help with workflows.  My Inventor work flows are not compatible.
Accepted solutions (4)
Replies (12)
Message 2 of 13
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
Message 3 of 13
sonnie_b
My apologies, I thought this was a very elementary question and would not require attaching a model.
Message 4 of 13
sonnie_b
Attached in a post reply.
Message 5 of 13
jhackney1972
Fusion does not have the ability to merge sheet metal bodies together so your flange has to be created and the profile shape cut from it.  Model attached.
Message 6 of 13
sonnie_b
Thank you.  That is basically the conclusion I came to through trial and error, but wanted to make sure I wasn't missing something and waste time learning that path if there was something easier or better.  Looks like the bend reliefs need to be added manually, see attached.  I could see this workflow possibly becoming problematic in certain situations if the bend reliefs are not automatically applied.   Any alternative methods you can think of that might include the automatically applied bend reliefs?  Maybe a flatten and fold approach or a top down approach, vs. my bottom up?  I am just too new to Fusion sheetmetal and find myself frustratingly handcuffed using it compared to Inventor, so still trying to understand workflow limitations.
Message 7 of 13
TheCADWhisperer
@sonnie_b
(view in My Videos)
Message 8 of 13
sonnie_b
Thanks for the video, very helpful.
Message 9 of 13
SaeedHamza
Here is my way of doing it where I used a small trick of creating an extra flange to extend into a new one, so not sure if it's okay for your design or for sheetmetal work in general as I'm not an expert in that area, but it's something worth considering.
Saeed Hamza
Message 10 of 13
sonnie_b
I included my technique in the attached part that I am, so far, happy with.  It approximates nearly exactly a similar part I make in Inventor, which was my goal.  I don't know if this is the most elegant or quickest.  It took me some time, but understanding how to use the contour flange tool was the key, along with the tips learned from all your comments.  Thanks for all the help
Message 11 of 13
johnsonshiue
Hi! As experts have already illustrated, there are multiple ways to create the desirable geometry. Here is another solution. Basically, create a Face Flange using the profile. Then use Push/Pull to get some clearance at the bend zone. Lastly, use Revolve command to create the bend.
Many thanks!
Software Test Engineer
Message 12 of 13
sonnie_b
I see that and thanks for this solution.  There are many ways to make the part, even without using the Sheetmetal tools..  The one problem I have with all of these methods is that the sheetmetal rules are abandoned or have to be manually applied when adding material to a flange.  I am specifically referring to bend reliefs, but in your example the bend radius is set by the user, not the rule, and with no bend reliefs.  Is there a suggestions forum?  I looked but didn't see one.
Message 13 of 13
johnsonshiue
Hi! Please start a new thread articulating the exact feature request. I will make sure the project team is aware of the request.
Many thanks!
