complex fillets or alternative?
jamie.q.white
Message 1 of 9
jamie.q.white
Some of my designs can't be 3D printed due to sharp creases that cause intractable thermal stresses.  Simply trying to add a fillet to the crease does not work because the fillet command fails.  Is there a good way to add material to the creases so that they are not as sharp?
Thanks!
-jamie
Replies (8)
Message 2 of 9
jamie.q.white
Oops, forgot.  Here are the relevant files:
Message 3 of 9
Have you tried modeling a surface with the curvature you want and using replace face to turn the flat valley of the the slot into a curved fillet?  I've used the approach before with other software on very difficult fillets.
Message 4 of 9
jamie.q.white
Thanks for the suggestion.  If I were to do the designs again from scratch, I would sculpt the intersection of the surfaces, which is similar to what I think you're describing. At this point,  I'm trying to avoid re-doing the designs.
-jamie
Message 5 of 9
I'm taking a break from most computers for awhile 😉 but looking at your picture I would maybe try splitting the two inward facing faces near the tight corner and doing a loft (in Model or Patch, the latter requiring by Boundary Fill) between these two resulting short faces near the corner.  If needed you could also sketch a guide rail for the loft to get the desired "radius" to the loft.
Jesse
Message 6 of 9
jamie.q.white
Hi Jesse,
Thanks for having a look. I can see how your idea would work.  I tried a loft along the crease, but across the crease is better.  I'll give it a try and see how difficult it turns out to be.
-jamie
Message 7 of 9
innovatenate
Autodesk Support
Autodesk Support
This may be a good opportunity to test the max fillet script.
You can check out more about @MichaelAubry's script in the below link.
https://fusion360.autodesk.com/projects/max-fillet-script-tool
Otherwise, you may have to use a variable fillet where the radius is smaller in areas of high curvature.
I hope this helps.
Nathan Chandler
Principal Specialist
Message 8 of 9
jamie.q.white
I am still struggling with complex fillets:  3D printed titanium parts cannot have sharp intersections. I spend a lot of time trying to fillet complex curves:
on the lower pipe, I need the fillet to be r = 2mm, but 0.5mm seems to be the maximum.  Sometimes I have some luck filling in the fillet curve with a small pipe and filleting the pipe intersections (upper structure), but this often fails as well.
How does the fillet command generate a fillet? Perhaps if I understood better how the command works, I might have more luck.
Here's a the file I've been working on (downloadable): http://a360.co/1hlHxe1
Thanks!
-jamie
Message 9 of 9
O.Tan
Oh wow, you have access to an EOS 3D Printer? Sweet!
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
