Complex design
Complex design
Oluwayimika_OLA
Complex design
Oluwayimika_OLA
Hello, I'm trying to design the silicone part of this grip and I've been having a tough time.
I tried using quad ball but it's just so hard to form the required shape. Is there a way I can loft a cylinder to a sphere?
TrippyLighting
Can you share your modeling approach by exporting the file as a .f3d and attaching it to a post?
I would design the overall shape as a T-Spine(form) and then split it apart into the individual parts.
Then I would refine the individual parts.
Oluwayimika_OLA
Thank you so much for your help
johnsonshiue
Hi! I guess you might want to consider a revolved shape and then use Non-Uniform Scale to deform it. But without seeing your attempt, I cannot say it for sure.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Oluwayimika_OLA
I was able to use sweep for the shape. I used a straight path and a curved rail
Oluwayimika_OLA
