Common Model Libraries
Hey, if I would like to use some very common standardized parts in my design, is there a place that I can go to load them in so that I don't need to design them myself?
For example, I am designing some PVC furniture at the moment and would like to use some standard Schedule 40 PVC pipes and fittings. Is there a library for PVC? I would also like to attach casters to the legs. Clearly I will be buying casters to attach when it comes time to make my furniture, so I'd be thrilled if there was a catalog of parts that included casters.
Is this possible?
Thanks!
TrippyLighting
Mc MAster Carr
CrabCAD
3DContentCentral
Traceparts
Cadenas
I could continue this list with hundreds if not thousands of vendors that make their products available in form of 3D models.
So how do I access this treasure trove of models? Is there a marketplace feature built into Fusion 360? I have not been able to find one if there is. Or do I need to hunt around websites and download files? If so, can they be added to Fusion 360 so that they are easily accessible as a library or do the individual models need to be imported into my project one at a time?
TrippyLighting
If you want to build a lire you'll have to download the manufacturer components individually and build yourself a library "by hand" using a Folder structure in the data panel.
ToddHarris7556
@TrippyLighting has already covered it... there are lots of online suppliers that have great catlogs. McMaster is (IMO) the easiest and most useful.
Just to be clear - though there are great sources of parts online, Fusion's ability to create/manage a parts library locally probably isn't one of it's stengths (again, IMO). Meaning, simply, that it's not quite elegant/easy to download a bunch of standard parts and create your own 'parts library'. You can.... kinda/sorta. You can create a dedicated 'library' project, and download all your standard parts to there. Then you can link them in to any project you like. If you're going to take that approach, I would recommend setting up a well thought-out folder system within your Library project.
Otherwise, your can certainly download MMC parts - or any other parts - one at a time and insert into your designs. I'm not disparaging it in any way, but it's not anywhere near the same as creating an Inventor Content Center entry, or creating an easily-usable 'Library'.
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
