Combining two objects without the seam
Hi--
In the example picture I have two components that I formed the same way: I sketched one half of it, then mirrored the sketch (using the same plane) to get the whole.
After doing this, I combined the two "half" bodies to get a whole (new component).
One one, the seam disappears. It will show up if I keep ON the two halves as individual bodies.
On the other, I cannot understand why the seam doesn't disappear despite turning OFF the individual bodies.
Anyone?
Big Thanx for your reply.
-Greg
neljoshua
@Anonymous,
Have you tried mirroring the feature rather than the sketch?  I just tried it and if I use a sketch to create a body, mirror the body, and then use a combine, there is no seam.  I read that it is sometimes better to let Fusion handle mirrors and patterns in the model environment rather than in the sketch environment (although I admit to having done both).
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Well, maybe this is something I should try.
Honestly, i don't remember if this is how I mirrored the first example component.
I have to investigate how to mirror a body.
Thanx
Will let you know.
-G
