Combining mirrored sketch with original
I'm trying to combine a mirrored sketch with the original open sketch and can't seem to figure this out.
Anyone have a solution?
Hi @Anonymous
See if this helps.
https://www.youtube.com/watch?v=LkPDJltxJnA
@Anonymous
I miss read your post, sorry.
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply so I could have a look at what you are trying to do.
etfrench
Edit the original sketch, then use the project command to copy the mirrored sketch contents would be one way.
Is the mirrored sketch on the same plane as the original?  If so, it would be easier to just redo the mirror in the original sketch.
ETFrench
