Hi, all!
I'm struggling with using an alternative bottom for a case. I have a case 240x240mm with wall thickness of 2mm. The bottom should have either a "massive" wall or a "hexagon" wall. So I decided to have that bottom wall as a separate component. While "massive" is absolutely no problem by just extruding a rectangle, I can't figure out how to combine the "hexagon" bottom with the rest of the case.
I have created a hexagon, shifted it slightly to x+/y+ and extruded it z+. Then I copied it (rectangular) once to x+/y+. Those 2 then are copied (rectangular again) a few times x+ and y+ to get the complete plate. Unf. the outer parts are extending the case edges of the other sketch.
What would be the best way to cut the exceeding edges off of the hexagon plate? Or did I just have used a wrong approach for this alltogether? I tried it with all parts in one sketch, but the extrusion gave me either a tremendous amount of bodies after rect.align ("new body") or simply nothing ("combine").
Ah, and: The case has some parameters, for instance "width" (x) and "depth" (y). So I don't want constant dimensions on the hexagon plate, but let them adjust to the rest of the case automagically, too. The diameter of a single hexagon is a parameter, too.
Hopefully I described my problem exactly enough and anybody can help me with that.
Michael
