Combining copied bodies
I am modelling an engine crankcase design, and since it has a lot of recurring geometry, I drew up one "bay" of the case, then copied / moved it to create the other 2 bays. They show as separate components, and arent locked.
I need to combine all 3 into one component so I can continue the case ends. As they are linked together I cant change one end without all of them changing. When I chose the "Combine" command, I can select the parent body, but the other (tool) bodies are not selectable. The bodies are physically touching. What do I need to do to combine them?
