Combine Tool Not Working
Hi everyone,
I am trying to combine a loft I made of a canoe using a lot of cross sections. I lofted half of the canoe and mirrored the other half using one of the origin planes. The problem arises when I try to combine the 2 pieces I make. I get an error that reads something that tells me that the intersection occurs at the same point, therefore they don't overlap and can't be connected. Any tips? I have attached my .f3d file below. This file might look familiar for some so I apologize for not knowing how to go about this properly.
Thank you once again. Look forward to hearing your responses.
davebYYPCU
If you hide body 9, then body 8 and 7 combine as join, quite ok, at my end.
Are you trying to combine body 9 to something? then there is an error.
Might help...
I have no idea what I did differently but it works now thank you
