Combine Problems after Moving (tilting/angling) a Body
ducaticorse
ducaticorse
Here's one I could use some help with:
Pretty simple 3D model.  One main body and one that I created as a "tool" to cut material from the main body.  The tool body functions fine for Combine function until I execute a Move command that includes and angle (to tilt the tool).  After that command (and when the two bodies are VERY MUCH still in interference with one another, both the Inspect/Interference tool show no interference and the Combine tool says that the bodies are not touching.
After doing some reading here, I've tried "nudging" the tool body after applying the angle, but no no avail.
Two bodies.  Finned body is the main part.  Simple cylinder is the "tool" body.
Screen Shot 2016-09-27 at 10.21.30 AM.jpgScreen Shot 2016-09-27 at 10.21.53 AM.jpgScreen Shot 2016-09-27 at 10.22.44 AM.jpgScreen Shot 2016-09-27 at 10.22.56 AM.jpgScreen Shot 2016-09-27 at 10.23.12 AM.jpg
TrippyLighting
You could not possibly convinced to do a screencast ?
It integrates very nicely with Fusion 360 and for workflow topics might be easlier to digest than the screenshots, even though these are nice.
ducaticorse
Sure, here you go.  It's a strange one!
TrippyLighting
That looks indeed like a bug!
As you are working on a mac I see the same problem with full resolution (2560 x 1440) screencasts than on my mac in that the visual quality the screencast tool creates is dismal.
Phil.E
The best way to get a good clear screencast is to make Fusion as small as possible. Then all the text and icons will appear much larger in the screencast window.
I'm looking into this and will log the bug when I can reproduce it. If you can export and share the model it will speed things along.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
I can't reproduce this in a simple case in our next release build (not yet out). It may be fixed, or I may just need your data. Can you please share the file?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
