Combine / join 2 spline curves to a single one
There is "Break" operation in Sketch menu. So, I draw multisegment spline, then a line, and then split my spline by this line in intersection point. After that I have 2 connected splines.
So, the question is:
Is there the reverse operation except "Undo" to have these 2 splines to be single again?
Of course I can constrain the joint point to have these 2 splines Tangent, Smooth, whatever. But will not return the single spline. I.e. I cant apply "Close spline" to close the gap between 2 splines.
In addition, I faced with another problem when I have 2 connected splines:
It's tricky a bit to get "Tangent handle" for one of splines in joint point. For one of curves it appears just after clicking on the curve or endpoint. But for the second curve it does not appear after clicking on corresponding spline. Even if I click on the endpoint, the handle is shown for another spline. So, I have either to move the joint point, or click on other point on selected curve to see "Tangent handle" which I need. See screencast.
