Combine bug
Combine bug
Combine bug
I am attempting to miter a tube using another tube as the tool and using combine-select target body-select tool body-cut-uncheck new component-check keep tool. Normally this results in the intended way, plus a chip I usually discard by removing instead of deleting.
However, today as I do this, in every case the wrong tube is cut. Reversing the selection of one tube as the target and the other tube as the body results in the same tube being cut again. Huh? Is there a bug?
In the screengrab, the cut is set up properly in the first shot, and in the second I hid the tube so you can see the cut.
Beyondforce
Hi @Anonymous,
Will you please make a screencast? it will be much easier to understand your challenge.
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
