Color Coded Subgroups in Browser
I accidently did a miss click and I turned on the color coded subgroups in the browser.  It seems like a great feature, however how do you turn it on and off?
Allan Steinkuhl
Found it.  I received an error message on the issue.
It is called  Color Cycling and it is under Inspect.
Allan Steinkuhl
neljoshua
If you like to, you can use the keyboard shortcut: "n".  Pressing it toggles component color cycling on and off.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
I guess that is how I toggled it on.
Thank you for your response.
Allan Steinkuhl
