Coil Feature - Semi Circle Section Addition Request
isocam
isocam
Hi Fusion Team,
Can you please add "Semi-Circle" as an option in the Section parameters for the "Coil" feature?
I design process vessels with semi circular ("D" shaped") tubes around the vessel shell.
This section would be a great help!
Many thanks in advance!
Darren
TheCADWhisperer
@isocam
Are you familiar with the Surface Sweep with Twist for path work around?
(Make sure the Profile is perpendicular to the Path.)
