coil error
coil error
coil error
Is there any way to  make a coil with a low pitch and the correct circle.
TrippyLighting
Yes. Definitely.
If you want more specific answers, you may wan to provide more specific data as to what the pitch, number of revolutions, mir diameter, major diameter etc. are.
helix angel is 6 deg with a .175 deg tapper and the tube dia is .0625" . I ended up using an angled plane rotated at the center of the tapered plug I drew and got a intersection curve that I could pipe . so much fun to machine thin graphite .
sorry I couldn't get back sooner
