Coffe Dripper - Help
This is my first attempt in Fusion 360. I am trying to model a coffee dripper, see images for reference. I cannot figure out how to model ridges inside of the cup, see detail image for more reference on how the groves look.
Any insights on how to accomplish this will be greatly appreciated.
Thank you,
laughingcreek
You could use something along the lines of projecting a line to a surface, and then either sweep a profile or use the pipe command on the projected line.
attached is a quick mock up of the thought.
Looks great! How did draw lines on the plane?
TrippyLighting
Have you ben through the tutorials in the Support & Learning section ?
