Cloud render results are thumbnails
hutchij
Thanks for reporting this.  This is not the intended presentation on the Mac and we will correct. That said, the behavior of the automatic renderings has changed. When the fusion model is saved, the automatic renderings are now intentionally lower resolution. (as you point out, they are thumbnails). This allows them to render very quickly. If you desire higher resolution, simply click the re-render button and choose the desired output resolution.  In about two weeks, we'll provide the ability to control the output resolution for automatic renderings per-view.
As I said, these should not be displayed so tiny on the Mac and this is indeed a bug.
John
adayan_adsk
Apologize for this problem. Unfortunately we can't reproduce this issue on our side.  Does this problem happen to all of you modals? Can you let me know which Mac OS you are using? Look forward to your response.
Ada Yan
Hi, yes, all of my renders look like this in Fusion. on A360 they are gorgeous. MacOS 10.8.5
adayan_adsk
Hi, we have fixed this bug. can you try again? thank you for your patience.
Ada Yan
Hi, I recently upgraded to Yosemite because of Fusion discontinuing support for 10.8.5. That said, as of today the thumbnail issue seems to be fixed.
