Cloud libraries on a360?
Sandflo
Message 1 of 8
Sandflo
Hi!
After watching this video https://youtu.be/waMpsv7HIKw and watching Curt talk about the cloud libraries, I wanted to try this out, but i cant seem to find the folders that he has on A360, i Only have my Project folders and some samples and learning folders!
I want to start using the cloud libraries but there are no were to be found!
I have the cloud libraries option ticked under settings, I on a Windows 8,1 OS
Please help me
__________________
Gigabyte P35 V3 , Windows 8.1, Sweden
Replies (7)
Message 2 of 8
adsloud
Please try to find the right place for cloud libraries folder as following: Click your Fusion ID on the top right corner of Fusion and then click My Profile. When you enter A360 page, click Data --> A360 DRIVE. The CAMPosts, CAMTools and CAMTemplates folders should be there.
But if you are the first time to use the CAM related tool libraries after June 20th release, there maybe no these folders there. You can create them by yourself in A360 and then upload your files. This is also mentioned in the Readme file of June release.
Debbie Lou
Sr. QA Engineer for HSM CAM
Message 3 of 8
Sandflo
Hi!
Found it,
But if i put a tool inte cloudlibrary on toolmanager, why doesn't it update on a360, i have set the update to 30 seconds
__________________
Message 4 of 8
adsloud
First, please make sure you created a new folder under the Cloud folder in the Tool Library dialog and put all the tools into this cloud sub folder. Then the upload to Cloud only happens after you close the Tool Library. Please wait for a moment for the sync workflow to finish and then reopen the Tool Library dialog to have a look.
Debbie
Debbie Lou
Message 5 of 8
Sandflo
This is how i did it!
1. export a local library
2 import it as a subfolder under cloud
3. close the manager and wait maybe 10 min.
4 open a360, data, a360drive, camtool,
STILL EMPTY, WHY
And how do i choose a postprocessor that I've stored in the cloud? When i want to PP?
__________________
Message 6 of 8
adsloud
The exact name for cloud tools folder in A360 should be CAMTools, can you please help confirm this? Sometimes the sync workflow is not so smooth due to A360 service. Maybe this is the reason. I will also keep an eye on this.
For Cloud Post Process, after invoking Post Process dialog, please click the Setup button on the right of the Configuration Folder text box and then select Use Cloud Posts. This is for Windows version. If on Mac OS, please choose the My Cloud Posts option in the Source drop-down list.
Debbie Lou
Message 7 of 8
Sandflo
Hi!
Thank you for you answer!
I uploaded a post thur a36 to to the post folder, but when i choose coud in the postdiag, its not there, and it has been over an hour sisnce ive uploaded it.
Please see attached video regarding this and the tool library missing on a360
http://autode.sk/1eGXHhj
__________________
Message 8 of 8
curtis.chan
Hey Johan,
Have you tried exporting the tool library, then placing it in the folder?  We have a hot fix coming out Friday, so hope this gets ironed out.  I'm thinking it's what Debbie mentioned, that there could be a delay with the a360 sync.  More to come...
