Closing the gap in an 'A'
Message 1 of 11
Hi there, I'm sure this is an easy solution but I'm completely new to CAD in general and F360 in particular.  Made a block of 'letters' and it worked perfectly except for the inner portion of the A - I can't get it to 'fill in'.  The small parts of the B worked and the D as well (as you can see from the image of the finished product) but the A is a mystery.  Is there an easy way to do this, even by drawing a triangle possibly?
Replies (10)
Message 2 of 11
SaeedHamza
use the text in sketch
here is a screencast for it
https://knowledge.autodesk.com/community/screencast/f8631063-6cde-41a4-9d54-d8745e464f5b
Regards, Saeed
Saeed Hamza
Message 3 of 11
I did - that's how I created every letter.  But when I extrude at a negative value (to create a void rather than an extrusion) the small part of the A doesn't fill in.
Message 4 of 11
It was the font.  I just tried it with Arial and it worked fine.  So something up with the particular font I was using I guess.
Would still be nice to know how to fill in that empty triangle if someone can offer an idea, but for the purposes of this piece it's solved.
Message 5 of 11
SaeedHamza
That happens, make the extrusion of the negative value as a new body, then combine cut
that sometimes solves this
Saeed Hamza
Message 6 of 11
daniel_lyall
What font was it ??
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 11
TrippyLighting
You can simply select the unwanted faces and delete them 😉
Message 8 of 11
SaeedHamza
@TrippyLighting I guess he meant that the triangle is not appearing, and he want it to do so ( Faces that you deleted )
Saeed Hamza
Message 9 of 11
TrippyLighting
Oops 😉
Message 10 of 11
etfrench
Explode the text, then either use the coincident command or extend/trim to close the geometry.
ETFrench
Message 11 of 11
Gill Sans Extra Bold
