clearance at inner cuts
narvi
narvi
Hi! i'm designing something ou of the plywood using boolean operations. And these components should go one into another. But when i use boolean there is no clearance. Is there a way of automatically adding some wiggle room using booleans?
HughesTooling
You can try Press Pull, select all the faces you need to offset then enter a minus offset.
Mark
Mark Hughes
Owner, Hughes Tooling
