clear cache to recover lost configuration entries
alan_wolf
alan_wolf
It seems that when I launch a configured design and open the configuration table there are entries missing, my list gets shorter and shorter. If I clear cache I might get the last one lost back, however, some configurations are lost and can only be found in older versions of the design, but I don't see a way to bring them forward to my current design with out re entry which is tedious and prone for errors. Ive also noticed that in drawings and switching configurations, they also fail because the configuration  may show selectable but not be there and then most likely a crash. Am I the only one experiencing this?
EvanGu
Hi @alan_wolf,
We have received reports of this issue from other users and are currently investigating the cause. May I ask, did you perform any specific actions before encountering this issue, or did it occur after saving and reopening after some time without any actions taken?
Evan Gu
Inventor/Fusion QA Engineer
gautham_kattethota
Hi @alan_wolf
I am not sure how you cleared the cache.  If it was by using the "Clear Cache Data" in "Support & Diagnostics", then that might not be sufficient.  Please follow the steps here https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Configured-Design-... by hard-deleting the cache from the hard drive directly and restart Fusion.  If this does not help to bring back the rows, follow the rest of the steps.
Gautham
Gautham Kattethota
Software Development
alan_wolf
The current bug fix in recent updates has fixed the problem and also fixed the drawing issues reported
gautham_kattethota
Good to hear. If there is nothing else on this topic @alan_wolf , please click on accept solution button.
Gautham
Gautham Kattethota
