Circular dependency
Circular dependency
Circular dependency
i get a circular dependency error,
but if i go back in the timeline before the combine7 it says causing the error it still gives me the error and i already deleted the sketch it mentions
laughingcreek
Does this model need to be parametric? looking at your modeling style I would guess no.  If not, then turn off your timeline and go into DM mode.  All will be well.
If yes, then start by correcting all the errors in your timeline (anything that is yellow or red)
yehsPDX
Dear baeyens_nico,
The circular dependency issue is a known one and Fusion has a fix in the latest release to prevent the situation happening again.
In terms of how to fixing existing design you have, I can only suggest deleting feature "Combine7" to break the loop. Doing this might cause some downstream feature removed but keep the most design intact.
Shu-Chieh
