Doug,
Thanks again for posting this question. I overlooked this originally. There is a caveat when trimming patterned sketch entities. When you create a sketch pattern, there is a small glyph that will enable you to re-edit that sketch pattern at a later time. At this time, this will prevent you from being able to trim patterned sketch entities. You can choose to delete the glyph, which will remove the ability to later edit the sketch pattern, and then trim the sketch entities. I've made a short screencast below to demonstrate this.
Please review the screencast and let me know if you have any questions.
Nathan Chandler
Principal Specialist
