circles always showing coincident. cannot dimension center to center distance.
best49erfan
best49erfan
I use fusion to draw holiday lighting props that use pixels.  i normally draw on lines and space the circles that hold the lights using dimensions.  now everytime i try to dimension them, they circles always say they are coincident and cannot be dimensioned to the value i select.
g-andresen
unfix the green (fixed) elements : Rightclick > FIX/UNFIX
However, it is easier with a pattern on path.
günther
