Changing profile outline on a curve
ryanZY2YJ
Message 1 of 11
ryanZY2YJ
I'm trying to create a ducted fan shroud that uses one airfoil profile at the bottom of the cylinder (6 o'clock) and morphs into another profile at 3 and 9 o'clock.
What would be the best way to go about doing this in fusion?
Thanks in advance for your help.
Replies (10)
Message 2 of 11
davebYYPCU
Create the LE and TE rails,
create ribs on origin planes, connected to those rails, then loft.
most ducts would not change airfoils, the picture supplied uses the same airfoil, and that would, be a revolve.
different story for the blade, but you didn't mention them.
Might help...
Message 3 of 11
ryanZY2YJ
Thanks Dave, I'll give that a try.
I'm working on a Custer channel wing, which does create lift. https://en.wikipedia.org/wiki/Custer_Channel_Wing
I'm just playing around. We'll see how this goes.
Ryan
Message 4 of 11
davebYYPCU
Be aware that Loft will try to shrinkwrap the surfaces, so some spar rails will help, but more than three ribs will likely be needed.
Message 5 of 11
ryanZY2YJ
How would I make ribs that morph form the one airfoil profile to the other? Is there a way to do this automatically?
Message 6 of 11
davebYYPCU
Not automatically,
Use 5 ribs in the half wing, and the leading edge as a centreline for the Loft,
Review the file, copied developed ribs to the Leading Edge.
Message 7 of 11
ryanZY2YJ
Thanks Dave. This is perfect!
Message 8 of 11
ryanZY2YJ
How do you figure out the correct profile of each of the ribs as each rib morphs from the one airfoil profile to the other?
Message 9 of 11
davebYYPCU
Step through the file with the timeline, something not sure of,
Right mouse click the timeline icon, and select edit feature to see my settings
I made the wing as a flat version, (random sizes - looks about right),
Made midplane construction planes
created sketches for the 3 unknown ribs.
Used Project > Intersect > Body and clicked the flat wing,
Created the leading edge circle, then an axis from the centre of the circle.
Plane at Angles from that line for the 3 inclined ribs,
Project > Intersect > Article for the LE curve / position, (purple point).
Copy pasted the flat ribs to the inclined sketches, aligned to the leading edge point (important bit).
Loft with centre line.
Should work ok, with your data.
Message 10 of 11
ryanZY2YJ
The part I am stuck on is how you made the sketches for three ribs.
How did you get them to have the correct graduation between the original two airfoil profiles?
Message 11 of 11
davebYYPCU
Create a Midplane, between both known ribs
Create two more mid planes between the centre plane and the known ribs.
created sketches for the 3 unknown ribs on the midplanes.
For each sketch - Project > Intersect > Body and clicked the flat wing. Stop sketch.
