Changing Appearance When Rendering Inventor Assembly Uploads
PatrickMacMahon
PatrickMacMahon
While assessing whether to purchase Fusion 360 as an added manufacturing application, we note that in Render mode when attempting to assign appearances to parts in an uploaded Inventor assembly,  we get the following error message:
"This component has appearances assigned to bodies or faces, they cannot be removed because they're in a referenced component.  The appearance you are applying will not have any effect to them. More Info"
Adjusting each part separately as suggested in Jeff Starter's tutorial is a non-starter as the parts will not open separately for some reason (and would be a formidable undertaking).
We used the same models a couple of years ago with no problems so any advice would be greatly appreciated.
CGBenner
@PatrickMacMahon
Hello, do you still need help with this question?
Chris Benner
PatrickMacMahon
Yes please.
PatrickMacMahon
Sorry.  There is no comment from your side.
CGBenner
@jeff_strater Do you have any advice for this topic?
Chris Benner
